Farmall Tractors Discussion Board
41 A Brakes Thanks You!
Posted by Doug (VA) on July 15, 1999 at 19:52:38 from (216.12.54.61):
With advise from several of you I was able to pull right side axle housing and axle. My mistakes were not enough WD 40 and not prying hard enough. Top and bottom axle housing dowel pins and brake dowel were rusty as you advised.
Have not attempted to reassemble. I plan to replace all bearings and seals on the back end so it will be a while.
As for balance when jacking rear of A the owner's manual advises placing a block of wood between left bottom of radiator and front axle. I did this and it seems to work.
Thanks again.
Post a Followup
: Re: 41 A Brakes Thanks You!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
