Farmall Tractors Discussion Board
Re: cub not charging
Posted by ltf in nc on July 19, 1999 at 13:03:17 from (206.228.213.21):
In Reply to: cub not charging posted by rick retter on July 19, 1999 at 11:27:19:
Strip the ends from a piece of insulated wire and connect one end to the field terminal at either the generator or regulator. Start the tractor and at a fast idle short the other end of the wire to a good ground. If the charge rate goes up, service the regulator. If the charge rate does not change, service the generator. This test assumes the battery is + grounded and the wiring is intact. If the battery ground is wrong, repost.
Post a Followup
: Re: Re: cub not charging
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
