Re: wiring up H 4 pos switch for 12v alternator setup?
Posted by Bob M on February 06, 2002 at 15:35:39 from (66.66.72.246):
In Reply to: wiring up H 4 pos switch for 12v alternator setup? posted by jmyt_47 on February 06, 2002 at 12:14:09:
You don't need to change a thing on the light switch. The existing headlight dimmer resistor will still dim the front lights in the "D" position, though it will dim them less than it did on 6 volts. Both the "L" and "H" positions will serve as an "off" position for the lights - but will have no other function.
Note there will be no wire connected to the generator field resistor. You can take the field resistor off the switch if you want a bit more room inside the ammeter box...
Post A Followup
: Re: Re: wiring up H 4 pos switch for 12v alternator setup?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
