Re: Play in Steering on A
Posted by Ramonared on February 06, 2002 at 20:09:27 from (63.251.115.229):
In Reply to: Play in Steering on A posted by Roy on February 06, 2002 at 18:48:28:
This is a common problem. The gearbox is not adjustable. It is however possible to replace the sector bushings and the bearings. The arm that connects to the tie-rods should have next to no free movement up and down. This is caused by worn bushings. The big nut on the front of the steering box retains the lower bearing for the steering wheel shaft and should be good and tight. If the steering wheel can be pulled towards you and away from you when you are in the seat; that lower bearing is shot. Also the tie rod ends are adjustable. Turn the steering most of the way in either direction. If the loosenes is now considerably less that means the gears are probably shot. Originally the gearboxes were filled with gear oil but often they get pumped full of chassis grease. A good used box is worth about $150. Don't pass on the tractor if the rest of it is good and is priced right.
Post A Followup
: Re: Re: Play in Steering on A
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
