Re: Piston Sleeve Seals
Posted by Big Jim on February 08, 2002 at 12:55:09 from (199.150.177.187):
In Reply to: Piston Sleeve Seals posted by Farmall Freddy on February 08, 2002 at 12:24:59:
Freddy, I am not familiar with a "C" myself, I am just guessing(farmall experts help me out!) that it is similiar to other older farmalls. All of the H's,M's, 400's, 460's, 706's, etc. have "dry" type sleeves. That is to say there are no O-rings. This type of sleeve requires a puller or shop press to remove. You can make your own puller out of some scrap iron and some 5/8" or 3/4" threaded rod. A round "stepped" disk will be required. This you will need to have a machine shop make. You will need to have the cylinder sleeve diameter for the machine shop. The stepped part of the disk is machined .01 under the bore diameter so it fits in the sleeve(from the bottom). A hole(5/8 or 3/4) is drilled in the exact center of the disk. The idea of this set up is that you put the threaded rod through disk which has been inserted in the bottom of the cylinder, on the top of the block you have a square u-shaped piece with a threaded hole in it the same size as your threaded rod. You put a nut on the top and as you turn it down it forces the u-shaped piece against the block and pulls upward on the disk which forces the sleeve up. Some sleeves are pretty tight and require a lot of elbow grease. There are probably other types of setups out there also, but I know this one works.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
