Re: 6 volt gen
Posted by steve on February 13, 2002 at 20:37:27 from (204.246.222.88):
In Reply to: 6 volt gen posted by Mike on February 12, 2002 at 19:56:12:
Your 6 volt generator will put out 12 volts. It will charge a 12 volt battery if you get the right voltage regulator. Just remember you are working it extra hard to get that voltage. If your "power" output is low (dont pull too many amps) it will be o.k. But if you try to get 10-15 amps out of it, it will overheat and eventually the generator will crap out. Also remember that most 6 volt generators are positive ground? If you put on a new regulator and 12 volt battery, would be best to continue + ground.
Post A Followup
: Re: Re: 6 volt gen
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
