Re: FARMALL 140 STEERING WOBBLE
Posted by Haas on March 07, 2002 at 19:24:55 from (129.37.117.239):
In Reply to: FARMALL 140 STEERING WOBBLE posted by RUSS P on March 07, 2002 at 18:38:38:
Several things to look for. The steering arm that hooks to the tie rods in front is held to the steering sector shaft by a big nut on the bottom. Hard to get to, but sometimes the nut works loose. If loose, you can move the arm up and down. Look for any play in the tie rod ball joints . You can tighten those up. You can take the big pluq with the hex on it out of the front of the steering box. You can then screw out the steering shaft worm gear enough to check the ball bearing on the end. If there is any play in the bearing, replace it. The bearing must be held tight to the shoulder on the shaft with the castle retainer nut tight against the inner race of the bearing. The bearing must be clamped tightly in the steering gear housing by the big plug with the hex bearing against the outer race of the bearing. If after checking all this, you have not solved the problem, then likely the sector shaft bearings are worn or the sector gear and worm are worn. No adjustments on them. You just have to remove the steering box and rebuild it, a pretty big job.
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
