Farmall Tractors Discussion Board
Follow-up to Overhaul Break-in Procedure on H
Posted by Bill(Tx) on August 02, 1999 at 15:57:49 from (192.105.235.146):
Fired her up on Saturday after the overhaul. After several miles up and down the farm-to-market road at various rpm's, she smoothed out very nicely at normal 'RUN' on the temperature. Part way down the road she started with a repetitive grinding and squeal, and of course the palms became immediately cold and sweaty in 100 degree heat. The fear faded when I determined that the fan belt was slipping on the crankshaft pulley. A noise in the area of a crankshaft will get your attention real fast. I never noticed that fan and generator hub assembly had been tightend against pulley with several loops of bailing wire. Evidently the nut to tighten the belt had been maxed out. Now I need to pull a functional water pump fan assembly (54 148 DA) from a parts tractor. The slippage doesn't raise the temperature that I can tell. Thanks to BKen and the Red on break-in's.
Post a Followup
: Re: Follow-up to Overhaul Break-in Procedure on H
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
