Farmall Tractors Discussion Board
Re: WILL THE M RUN?
Posted by The Red with some initial thoughts. on August 03, 1999 at 11:22:22 from (12.75.196.38):
In Reply to: WILL THE M RUN? posted by RANDY on August 03, 1999 at 10:11:02:
RANDY, I would say a slim chance since it has been outside. However this is how I would go about trying to start it.
First change the oil as a minimum. You will need 8 quarts of SAE 30 and a new filter You don't want to circulate 10 year old oil for sure. You are only talking $15 or so.
Pull the spark plugs and make sure to mark which wire goes where.
I would then pull it and use 5th gear. Let out the clutch slowly to determine whether the motor is stuck or not.
If it is loose, try 4th gear and again let the clutch out. I would try to get some decent oil pressure built up and drag it around a good 15 minutes.
Make sure the radiator is full of coolant or water.
Then stick on a good battery, decent spark plugs, FRESH GAS, and either crank or pull it.
This is only a starting point. You may have all sorts of problems before you get this machine running.
Post a Followup
: Re: Re: WILL THE M RUN?
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
