Farmall Tractors Discussion Board
Re: WILL THE M RUN?
Posted by Bob M on August 03, 1999 at 11:33:40 from (192.232.120.194):
In Reply to: WILL THE M RUN? posted by RANDY on August 03, 1999 at 10:11:02:
I acquired an M under similar circumstances. Had good luck doing the following:
1 -Drain the oil and refill with fresh. Put in a new filter too.
2 - Remove the spark plugs and shoot a couple ounces of motor oil or WD-40 into each jug.
3 - Now see if you can turn the motor. If you can, give it several revolutions, then....
4 - Install new spark plugs.
5 - Pop the distributor cap and wipe it dry inside. Clean and regap the points, or install a new set.
6 - Dump the gas tank, clean the sediment bowl and drain the carb (plug on the bottom of the carb bowl). Put in a couple gallons of fresh gas.
7 - Stick in a fresh battery, cross your fingers for luck and crank 'er up.
Good luck!
PS - Good idea to check for wasp nests around the fan, in the battery box, etc. before doing the above - I did not and wished later I had...
Post a Followup
: Re: Re: WILL THE M RUN?
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
