H bull pinion shaft bearing
Posted by Mike ISW on March 20, 2002 at 19:42:41 from (64.12.104.183):
I replaced the brake band and shaft seals on my "H" tonite on the left side. Disassembled the right hand side. The left side went so well I thought I may be able to get done with brakes and seals Thursday evening after work. BUT after removing right cover and drum I found bull pinion shaft had alot of up and down movement and the left was tight. Upon further inspection I found the outer bearing for bull shaft missing a couple balls. Now my question: What kind of job do I have now? Has anybody replaced these bearings? By looking at the service and parts manuals it appears the shaft will come out after removing the bearing retainer that's behind brake drum. Is this correct thinking? I appreciate any help and /or suggestions, Mike
Post A Followup
: Re: H bull pinion shaft bearing
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
