Re: 300 starts fast...
Posted by Bob M on March 23, 2002 at 05:53:28 from (66.66.72.246):
In Reply to: 300 starts fast... posted by Dick Davis on March 23, 2002 at 03:22:54:
Hi Dick - A couple possibilities - The coil might be overheating. If the PO 12 volted the tractor, re-used the existing 6 volt coil, and did NOT install a ballast resistor, the coil will draw too much current. The excess current will overheat the coil and can cause it to fail - it's also not good for the breaker points either. Try running the tractor again until it quits. Immediately pull of a plug wire, crank the motor and test for spark. If very weak or no spark, you found the problem. To correct, either install a ballast resistor in the coil primary or simply swap in a "12 volt" coil. The other possibility is there's a fuel flow restriction. Try removing the drain plug at the bottom of the carb. You should get a continuous solid flow of gas (not dripping). If not there's a restriction somewhere between the sediment bulb inlet at the bottom of the tank and the carb bowl, or the gas cap air vent is plugged. Good luck!! ...Bob M
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
