Farmall Tractors Discussion Board
Re: M Diesel Sleeve Problem
Posted by Roger on August 03, 1999 at 20:12:11 from (209.100.170.29):
In Reply to: M Diesel Sleeve Problem posted by C. Amick on August 03, 1999 at 09:43:09:
I am rebuilding a MD now and had a similar sleeve problem. The main problem with the MD is that the manual calls for the sleeves to project .041 to .047 inch above the top of the block. When I installed my new sleeves they didn't project above the block nearly that much. I didn't understand why this was the case until I went to install the head. When I set the head gasket on the block I discovered that it's bore was larger than the sleeve upper shoulder and the sleeve must stick up enough so that it is against the head when the head bolts are torqued down. I ended up getting shims to shim the sleeves up to the .045 inch spec. My sleeves were not real tight either after I had the block cleaned at the local auto shop. I have the engine all reassembled, but haven't started my tractor yet as I am still working on other parts of the tractor. That whole system makes me nervous as to how it will work.
Roger
Post a Followup
: Re: Re: M Diesel Sleeve Problem
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
