Re: Farmalldan - powersteering working / but
Posted by farmalldan on March 27, 2002 at 06:18:39 from (64.154.26.248):
In Reply to: Farmalldan - powersteering working / but posted by boog on March 26, 2002 at 19:43:15:
Boog, This is about what I expected. First, let me quote from the owner's manual for the flow control valve: "The Hydraulic Remote Control Attachment is used with the Farmall Lift-All system when operating tractor-trailing implements. Pull the Lift-All control rod all the way back and lock it in place with the control rod latch. Unlatch the remote control valve lever.........." As you can see, your system appears to operate as designed. Now, a question. When you pull the Lift-all rod back, does the engine load up? If so, is the flow control lever in the neutral position (the flow control should have three positions: up, neutral or hold, and down.)? I would not expect a change in engine sound when you pull the Lift-all rod if the flow control is in neutral. However, if the engine loads up when both rods are pulled back, this is normal since I am presuming you have all outlets (Lift-all and flow control) plugged. This causes the pump output to go over the system relief valve at maximum pressure. With a hydraulic cylinder installed, the system will only put up as much pressure as required to operate the cylinder until the end of its stroke is reached. Thus, you won't experience the engine loading to the same extent in normal operation. Let me know what you find out.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
