Farmall Tractors Discussion Board
Re: Re: Re: Wiring Diagram for '50 H
Posted by The Red on August 04, 1999 at 12:16:34 from (12.75.198.141):
In Reply to: Re: Re: Wiring Diagram for '50 H posted by grant on August 04, 1999 at 11:50:16:
Grant that is exactly what I did with my 51H. I preferred the VR on top of the generator. If you have $35 or so, Ken Updike has the harness. It's a tad short from the original but will do. 608-455-2411.
If you want to make one, either do a 12-2 house wire or 12-3 if you want the coil wire to route with the other two.
Do you have a low charge, high charge, dim light, bright light switch as the first question?
Assuming you have the above switch, its pretty simple to wire.
The wire from the bat terminal on the VR goes to the right post on the ampmeter when you are looking at the back of the light switch plate. This right post should also have your wire to the light assembly and to the coil switch. The left ampmeter post is from the battery via the starter switch.
The second wire goes from the field post off the generator to the lower farthest right hand screw on the light switch assembly.
Post a Followup
: Re: Re: Re: Re: Wiring Diagram for '50 H
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
