Re: M radiator removal, and other ????'s
Posted by Michael Soldan on April 04, 2002 at 20:07:50 from (216.46.130.77):
In Reply to: M radiator removal, and other ????'s posted by Ken Christopherson on April 04, 2002 at 18:14:50:
Ken, I have had a great deal of success with oven cleaner on degreasing jobs but you have to help it. Scrape the heavy deposits of grease with a putty knife, a wire brush is very helpful. I have then applied some varsol with a spray container and let it soak . Then give the oven cleaner in even layers over greasy areas and then go away for a while. A pressure washer will then strip away the areas you have "oven cleaned" You may have to repeat the process on areas around the manifold where the grease is baked on and it may lift some paint. Re the radiator, its been a while since I've had mine off but I have. I recall we removed the bolts in the side rails and wiggled the front end ahead a few inches, giving us just enough room to get the bolts off, I have two H's and the same problem exists in removing the rad. There is no easy way.."half lap over" which is a tiny turn with the wrench, flip the wrench for another tiny turn and so on, or sometimes a short handled gear wrench fits up in. When you reassemble the rad put an anti seize on the bolts and do not tighten them real tight..your tractor is not likely bouncing over plowed fields and the anti seize will allow for easy removal again. If you are getting your rad done at a rad shop you can get new bolts soldered in . Re painting little parts I do what you suggest,wire hooks hanging from the door tracks filled with parts ...The swinging drawbar needs a huge 3\4 Johnson bar and likely a piece of pipe over the end for more leverage. You may even need to heat the bolts to get them out. I work in an auto repair shop and hardly a day goes by that we don't have to heat something red hot and then douse it with water, that sudden contraction breaks the bolt loose of rust and being seized and it usually turns off easily. Sometimes an exhaust nut will come off red hot but most seized items we douse. Even a propane torch on a bolt getting it hot will release it. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
