Farmall Tractors Discussion Board |
Re: Re: Re: slipping clutch
Posted by Ed on August 06, 1999 at 10:14:42 from (167.173.8.6):
In Reply to: Re: Re: slipping clutch posted by carl in nc on August 06, 1999 at 04:31:13:
On the IH tractors in my family the T/A would actup when going from high to low or not work at all in low. Generally High would always work. I'm assuming you've tried to adjust. 1.) When the new clutch was put in did anybody check out the flywheel? Was it worn out or cut beyond limits? 2.) Were all the new parts with in spec. 3.) How bad was the clutch? could the T/A have been the problem all along and you replaced a good clutch? 4.) Was the clutch put in correctly?
Post a Followup
