Farmall Tractors Discussion Board
Farmall M wiring problem
Posted by Bob Bennett on August 06, 1999 at 23:27:52 from (207.227.238.16):
Recently bought a Farmall M that had a unfinshed backyard 12V conversion done with alternator. I'm in need of a wiring diagram showing how to connect all the components. Including all the contacts in the light switch/ammeter box with fuse, push/pull-ignition switch with two leads, alternator with Bat/r/f wiring connections, ballast resistor, 12V coil, distributor. I got the lights to work so I know they are hooked up correctly. The light switch only has three positions on it chg/dim/bright. Thanks for the help. Fax # (360) 697-7747
Post a Followup
: Re: Farmall M wiring problem
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
