Re: Hard to start Farmall 140
Posted by Daniel Kelley on April 18, 2002 at 11:34:08 from (216.229.35.91):
In Reply to: Hard to start Farmall 140 posted by JDeLong on April 18, 2002 at 11:00:05:
Checklist: 1) Check the voltage on your system before and after starting. Before starting, it should be a little over 6v. With the engine running, it should be considerably over 6v. (I'm used to 12v systems, where it is 12.5v before starting and 14v while running.) a) If the voltage is under 6v before starting, charge the battery and check again. b) If the voltage is still under 6v after charging, replace the battery. c) If the voltage does not increase while running, check the generator. Clean the terminals on the generator. Check/adjust/replace the voltage regulator. Heck, sometimes just tapping the generator lightly is enough to get it genning again. d) If the voltage still does not come up significantly above 6v while running, try a replacement generator/alternator. 2) Check your battery cables. Corroded cables and ends can lead to a voltage drop, leading to drained batteries and burned-out starter motors. Less volts = more amps. 3) Check your starter switch. If it looks ancient, get a replacement. 4) Consider upgrading to a 12v system, and then consider the Ford solinoid solution I gave as a response to "Starter problems" in this discussion list.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
