Farmall Tractors Discussion Board
Re: Re: Farmall A Cooling
Posted by The Red with followup on August 08, 1999 at 12:30:47 from (12.75.221.58):
In Reply to: Re: Farmall A Cooling posted by The Red on August 08, 1999 at 12:24:23:
Ray, sorry you did post both places. I just saw your post here.
I just looked in an old IT shop manual I have and you should have 50-60 psi with near full throttle, which is similar to the H. Anything below about 10 psi and you are not getting enough oil circulation.
Either the collection screen on the bottom of the oil pump is leaking or you have a leak in the pump. If its like the H, there are two halves to the pump housing with a gasket. You may be leaking there.
In any event, you are doing damage at that low of PSI unless your gauge is faulty.
Post a Followup
: Re: Re: Re: Farmall A Cooling
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
