Re: FAA No start checklist
Posted by Andy Martin on May 30, 2002 at 05:34:17 from (12.74.161.183):
In Reply to: FAA No start checklist posted by Joseph P on May 30, 2002 at 05:05:31:
1 Pull center wire from distributor cap and hold end close to block while someone cranks engine. If magneto is firing you will get blue sparks at least 1/4 inch long. Use insulated pliers to hold the wire or you may not need to see the spark, you will feel it. 2 If center wire does not fire you need to repair the magneto or replace the wire. You can use a piece of house wiring to check for spark. If the kit or new wire does not help a local magneto shop can. Check the yellow pages. Timing is insignificant if there is no spark. 3 If center wire fires check any other wire. Pull it off the spark plug and hold close to the block. This checks that the rotor bug and cap are OK. If no spark now after spark form the center wire then replace the rotor bug and cap. 4 If you get a spark at the end of the wire but not when you attach a spark plug to the wire then you need new soark plugs. They can go bad just sitting. 5 If you have spark to the plugs check compression by holding your finger over No. 1 spark plug hole while someone cranks the engine. The compression will blow by your finger on the compression stroke so you can stop them from cranking the engine when this happens and look at where the rotor is pointing. It should be st or just past No. 1 terminal. To avoid getting bit when cranking the engine pull the heavy wire from the magneto to keep the spark in the magneto.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
