Re: generator not charging, or battery losing charge
Posted by Haas on June 02, 2002 at 15:08:00 from (166.72.245.211):
In Reply to: generator not charging, or battery losing charge posted by tom on June 02, 2002 at 04:50:17:
Sounds like your generator is not charging, or you have a problem with the regulator. As others said, try polarizing the generator. If that does not work, make sure your regulator has a good ground. Paint under the mounting lugs of the regulator can be enough resistance to keep the regulator from working and charging the batter. Put a wire under the generator mounting lug and connect it to the battery ground and see it it starts charging. Also to check if the generator is working, connect a wire to the field (F) terminal and with the tractor running ground that to the battery ground. If the generator is working, it should show charge. If the regulator is properly grounded and you only get charge when you ground the field terminal of the generator, then the regulator is bad. Make sure to NOT ground the ARM or GEN terminal of the generator. You can ruin the generator.
Post A Followup
: Re: Re: generator not charging, or battery losing charge
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
