Farmall Tractors Discussion Board
Re: M Diesel Sleeve Problem
Posted by Richard on August 13, 1999 at 07:20:54 from (156.46.71.220):
In Reply to: M Diesel Sleeve Problem posted by C. Amick on August 03, 1999 at 09:43:09:
Don't run the engine with the sleeves that way you will ruin the sleeves, You have a problem as the sleeves should be very tight and if they are not they will move around and also you have to have a tight fit for heat transfer. You either have the wrong sleeves or someone has machined the bores for some problem in the past, I suggest you get someone to mike the bores for you and also the sleeves to see if there is a problem the sleeves should be a little bigger o.d then the bores inside dia. so you have a crush fit. Diesels are very fussy as they operate at much higher pressures then gas engines and things have to be right. I have four of these engines and have never had that problem.
Post a Followup
: Re: Re: M Diesel Sleeve Problem
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
