Re: Re: Bearing retrofit IH 350 Utility
Posted by Frank on June 09, 2002 at 19:51:50 from (198.81.16.168):
In Reply to: Re: Bearing retrofit IH 350 Utility posted by scott AR on June 09, 2002 at 18:24:13:
Scott.....I'm assuming that you have a manual steering box. They're pretty simple but a lousy design. The upper and lower ends of the worm gear on the steering shaft form 1/2 of the bearing races. 5/16" dia balls run on them and are held in place by replaceable cups upper and lower(the other half of the bearing races) Tension is adjusted by shims under the steering shaft housing (4 bolts hold it in place) If you don't have vertical play on your steering shaft, before messing with bearing adjustment, I'd back off the box adjustment screws (one on each side of the box with a lock nut around it) and then tighten each a little and test to see if you get any improvement. Good luck!
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
