Re: M.D.
Posted by Bob M on June 15, 2002 at 09:55:35 from (24.169.120.138):
In Reply to: M.D. posted by bob on June 15, 2002 at 09:08:38:
Bob - First thing I'd do is check the ignition timing. Sounds like maybe the ignition wires are connected wrong, or the distributor is way out of time. To check take the plugs out and lay the #1 plug on the block with it's wire connected. Now use your thumb to feel for pressure on the #1 plug opening as an assistant turns the crank (indicating #1 is coming up on compression stroke). Now turn on the ignition and continue to turn the crank while watching the timing mark for #1 TDC - you should get a spark almost exactly at TDC if it's timed/wired correctly. If not you've found the problem. If the ignition checks out, THEN suspect a starting valve or manifold butterfly problem. Try cranking the motor a few seconds with the the starting lever in "start" position and the choke full on, then immediately pull a spark plug. If everything is working right the plug should be wet with, or at least smell of gas. Good luck!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
