Farmall Tractors Discussion Board
Update on 350 runs but misses - still need help!
Posted by Gill on August 16, 1999 at 18:45:33 from (208.235.2.104):
Okay, so far I have changed plugs, wires, distributor cap, rotor, points, condensor and coil. Adjusted carb to run leaner, checked governor springs in distributor. Still misses just like when I started working on it. It must be something either stuck or broken, because problem started all of a sudden. Compression checks 140 psi on all four cylinders. Could problem be stuck exhaust valve? Thanks for your earlier suggestions.
Post a Followup
: Re: Update on 350 runs but misses - still need help!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
