Re: Re: Re: Alternator Conversion
Posted by Doug in OR on July 22, 2002 at 09:05:36 from (159.121.94.198):
In Reply to: Re: Re: Alternator Conversion posted by Andy Elsner on July 22, 2002 at 08:16:57:
This assumes you will be using a Delco 10SI alternator and is already a 12 volt, negative ground system. Remove the regulator and generator. Keep track of where the BAT wire from the regulator goes. This is where you will connect the wire from the BAT terminal on the alternator. The GEN and F or FIELD wires to/from the generator and regulator will be completely removed. Tape them off if you wish. If your regulator has a L (lights) terminal, don't use this wire either. If this is your case, tie this wire to any hot battery connection - probably at the ammeter. Include all appropriate fuses. Otherwise, wire the alternator as described in the articles. Take BAT from the alternator (using heavy wire - AWG 10 if possible) and connect it to where your regulator BAT wire went. Connect pin 2 on to alternator to the BAT stud on the alternator. Connect alternator pin 1 to your ignition switch.. through the indicator light/diode/resistor - depending on how you wish to configure this exciter terminal. I didn't note if your tractor was a diesel - if it is, you can probably connect the alternator pin 1 wire directly to the ignition switch. I recommend wiring this through a 47 ohm, 2 watt resistor if you decide to eliminate the indicator light or diode - as a current limiter in case you develope a wire short or alternator problem As for pulley size, try to make the alternator pulley 1/3 the size of the drive pulley. If you can't find a pulley that small, do the best you can.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
