Farmall Tractors Discussion Board
Re: Super A rear wheel seals.
Posted by Daniel on August 17, 1999 at 10:32:20 from (206.74.50.21):
In Reply to: Super A rear wheel seals. posted by Rich Benson on August 16, 1999 at 22:24:51:
Inside the final drive housings there is a domed cover on each side. (unless you have a gear to drive a fert. dist. or planter)Under the cover is a bolt that holds the axel. Drop the pans on the final drive and put a piece of plywood under the gear, be ready to catch it when it falls. Note which is the inside of the gear, it will go back both ways but only work the right way. The felt seal ring in the outer axle cover is a pain in the neck to put back in. Good luck. Daniel. DAH2888@aol.com
Post a Followup
: Re: Re: Super A rear wheel seals.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
