Distributor / Tach gauge
Posted by Mike on August 04, 2002 at 17:31:41 from (12.216.50.95):
I put a new temp gauge on the 460 yesterday and was looking at the tach gauge to see what it needs to work.
No cable. However it wouldn't fit anyway. The distributor is in at a goofy angle. It is turned so the cable would come out right into the block, don't think it would fit.
Apparently somebody tinkered with this old girl and put it in turned.
Doesn't this mess up the fire order or the timing or something?
I always thought they had to go in at the same way they came out. Could be they corrected it with the timing or something. Tractor runs good.
I don't know squat about distributors, can it be pulled and put in with the correct angle? From pictures it looks like the cable and gears should come right out parallel to the engine and it makes a straight shot to the dash.
Thanks
Post A Followup
: Re: Distributor / Tach gauge
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
