Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter
Posted by dick on August 07, 2002 at 09:16:54 from (209.245.8.101):
In Reply to: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter posted by Kilian on August 06, 2002 at 12:51:00:
The new clue pretty well nails it down. The pump is running at high pressure all the time, and being protected by the pressure relief valve (which is working as intended from your description). When you move the steering wheel, part of the hydraulic flow goes to the steering instead of through the relief valve, so the pump isn't working as hard and sounds happier. The problem is almost certainly in the unloading mechanism which is supposed to let the pump just circulate oil at low pressure except when high pressure is actually needed. The problem is most likely a clogged orifice (part 10 in Figure IH748 in my IT manual, hopefully yours as well). Lack of flow through this orifice prevents unloading, and is a fairly common problem. A less likely suspect is a leaky O-ring (part 4, same drawing) which could also interfere with the unloading mechanism. An external leak in the control line could possibly be your problem (if this is what you mean by bleed out). If your hitch will hold a heavy load without bleeding down, the cross-check valve is working OK and I wouldn't mess with it. The ports on that valve tend to be a real pain to get apart, so it's a good job to avoid, if possible. Good luck, let us know how you make out.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
