Re: Two year storage - procedure
Posted by Don LC on August 11, 2002 at 06:56:33 from (24.166.248.35):
In Reply to: Two year storage - procedure posted by Dick Davis on August 11, 2002 at 04:25:00:
#1 Change oil & filter, the aicds in used oil is bad for the bearings. #2 Remove the sparg plugs and put a small amount of oil in each cylinder. Turn the engine over several times to pump the clean oil through the bearings and lube the rings and cylinder walls.. #3 replace the spark plugs. #4 Add "stable" to the gas tank and top it off.Turn off the gas valve under the tank and remove the drain plug on the carburator,to drain the gas line and carb...replace the plug..# 5 Remove the batteries to a place where they can't freeze (have a friend keep them up,or give them away or sell them)chances are they won't be much good after setting two years anyway..#6 change anti freese 50/50 mix (I use distilled water) this should be done first and run through the engine .. #7 air up the tires and block the tractor up to remove the weight off the tires.. #8 Breaks off and trans.in nutral..#9 cover the trastor ,with a car cover or old bed sheets..be sure the cover will let air and moisture, pass through (remove the muffler,makes it easier to cover...#10 make a list of what you have done, so when you come back you can re trace your steps..Atach a copy to the tractor..(before starting your tractor in two years,remove the spark plugs and turn the engine over several times to get oil throughout the system....you do this and your tracror will be fine.....good luck...Don
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
