Re: 1 Wire Alternator?
Posted by Bob M on August 14, 2002 at 08:53:11 from (165.170.128.66):
In Reply to: 1 Wire Alternator? posted by jmyt_47 on August 14, 2002 at 07:46:12:
If you wire the alternator per the diagram, an auxiliary diode is not required. For the warning light, any 12 volt bulb rated at about 200 milliamps will do. An auto instrument panel or side marker lamp bulb (#57, 168, 194, 1815, etc) works fine. A suitable lampholder can be purchased at Radio Shack or at a parts store. IMPORTANT! Make sure the lampholder is a 2-terminal (ungrounded) type! A grounded (single wire) lampholder will not work if it is grounded to the tractor.
If the charging system is working properly the ammeter should show a slight (2 - 4 amps) charge with the motor running at speed and a fully charged battery. However with a fully charged battery, the the ammeter should indicate a charge of 30 amps or more immediately after starting, then taper off to 2 - 4 amps after running a minute or two.
Post A Followup
: Re: Re: 1 Wire Alternator?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
