Re: H Pulley gearbox lube
Posted by Haas on August 19, 2002 at 03:47:30 from (166.72.245.27):
In Reply to: H Pulley gearbox lube posted by Chris/Mo on August 18, 2002 at 20:03:23:
The belt pulley gets lube from the transmission. However, when you change the oil in your transmission, you should loosen the three bolts that hold the pulley shaft retainer to the housing. Pull the shaft out and let the oil in the pulley housing drain. There is not a drain plug on it. The pulley housing is the high point of the transmission and water tends to condense there and accumulate. If you drain it, you'll probably get some water. When you reset the bolts that hold the flange, make sure the mating surfaces and the shims are absolutely clean. There is not gasket, only shims to set the gear lash, so if you get a spec of dirt between them, you're going to have a drip. After draining, put a quart or so of the same oil you use in your transmission into the fill plug on top of the pulley housing. The sump on the pulley housing only gets oil by splash up from the tranny, and pulley sump needs to be replenished separately. The pully sump has an overflow that drains back to the transmission, but there is always oil up there as there is no drain in the bottom.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
