Re: Magneto questions
Posted by Diesel Don on August 22, 2002 at 21:13:37 from (206.40.116.27):
In Reply to: Magneto questions posted by ScottyNY on August 21, 2002 at 17:03:42:
If my failing memory serves me right,your B and my A should have the same engine/bellhousing.That being the case,pull the #1 plug and place your finger over the hole.Crank the engine and soon you feel the compression blow your finger off the plug hole.Slowly crank until the blowing stops.You should be at or very near TDC on #1.Next,remove the hand hole cover from the bottom of the bell housing.Just under the flywheel,you will see an index mark.Look at the bottom edge of the flywheel and you will see a line with 1-4TDC stamped by it.You may need to clean up the flywheel to see it.Once you find the mark,line it up with the index under the flywheel.You are now at #1TDC.You may want to highlite the line on the flywheel with a paint stick so it is easier to find again if needed. When you install the mag,make a mark under the distributor cap on the metal below the #1 tower on the cap.Turn the mag until the rotor points at the mark.You'll feel the impulse spring wind up.Install the mag on the tractor.If you can't line it up and hold the spring,turn the engine backward a little and install the mag.Hand crank the engine and have someone watch the timing marks.The impulse coupling should trip just as the timing marks line up.It might take a couple tries.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
