Super C Teardown By Amateur
Posted by Don on August 30, 2002 at 11:16:01 from (208.11.82.163):
OK, I've started on this problem with 3 extra quarts of oil in the crankcase plus a small amount of water. Been advised, thru this web site, & I appreciated the info, That the causes could be: Bad head gasket Bad O-ring at the bottom of a piston sleeve Warped head *The above is said to be water in oil problem) (I would also think the head could be cracked or the block is cracked but I doubt this as tractor was starting & running good.) Excess oil problem. A Mr. Paul Shuler told me this came from the hydraulic pump and after reading the manual it states that this can be a problem. However one problem at a time. So, I'm to the point where the head is off the tractor and the old head gasket is now seperated by itself. But you know what, As I look at it I can see nothing wrong with it. My mind tells me that if it was bad I should see a broken spot or at least a bad spot. Then I get to thinking,(watch out) as I untorqued the head bolts they were not all torqued the same. Two were at 35, two at 65, and one each at 40, 45, 50, 55 and 75 (9 head bolts). This was done with a craftsman wrench with a pointer and its hard to get the exact breaking point but the above figures are close. Can I rely on the torque wrench figure used in this manner. I would think there should not have been this much variance. It appears the tractor was never worked on before, surely the factory would not have done something like this when the manual calls for 80 foot lbs. (maybe the assembly man came to work drunk) If it is this uneven, could this be the problem allowing water to seep into the clyinders. Should I continue tearing down to look for damage at the sealing ring on the piston sleeve? Does anyone know what the torque is for the bolts on the rod bearings should I remove the pistons. I could not find it in my manals. Is it hard getting the sleeve out? Also would it be wise to reseat the valves a this time. If so, should I take the head (overhead valves) to a professional shop to have it done. Have any of you quys done your own and what tools do you need? I have only run the tractor for a few minutes since purchasing it last April and I didn't notice any blue smoke coming form the tractor at startup, while idleing or running down hill. Any of you fellows out there with experience I would appreciate some advice.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
