Re: battery charger harmful?
Posted by Bus Driver on September 05, 2002 at 17:45:31 from (65.165.152.118):
In Reply to: battery charger harmful? posted by Martin Kellner on September 05, 2002 at 07:51:43:
You did post that the start feature was 6 volt- have not personally seen that feature in other than 12 volt. If perhaps 12 volts was applied, the batteries could have been damaged. But the necessity to use the start feature indicates that the batteries sat at least partially discharged for a time- that is death to a lead-acid storage battery. The battery plates will sulfate if discharged and quickly will not accept a charge at all. Keep fully charged at all times. If the tractors sit near each other, make light gage 18 or 16 gage jumper wires with alligator clips from Radio Shack. Use a 12 volt trickle charger- the only voltage in which they are available, as far as I know. Jump positive of tractor #1 to the negative of tractor #2. Attach the negative of the charger to battery #1. Attach positive of the charger to positive of battery #2. This places the batteries in series as far as the charger is concerned. No need to disconnect the batteries from the tractor. But no metal from the two tractors touching each other. The charger I have has no output unless it senses a voltage from the battery. When ready to use a tractor, just disconnect the charger and the jumper(s) and crank the tractor. I store 2 riding mowers this way each winter. Since they are 12 volt, the jumper hookup is different.
Post A Followup
: Re: Re: battery charger harmful?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
