Re: 130 gears grind when shifting
Posted by Hugh MacKay on September 08, 2002 at 03:54:35 from (216.208.58.133):
In Reply to: 130 gears grind when shifting posted by CD on September 07, 2002 at 09:18:48:
As I take it, tractor has been idleing, you jump on and attempt to put in gear. If it is taking more than 5-10 seconds for transmission to stop turning you have something wrong. My immediate reaction is that your clutch disc is sticking on shaft, just enough so it will not come away from flywheel. I had this happen once, right after I had a new clutch and presure plate installed. If your tractor has sat for a lot of years or someone has installed a new clutch without thoroughly cleaning shaft and lubricating with white grease ( type used by auto industry on door hinges, etc.) You may have to split tractor and do this. Be carful not to use too much grease, as you don't want it getting on clutch disc facing. If your hand is small enough, and you can keep direction of spray right you might try a spray type lub., through hole on bottom of clutch housing. The danger here is getting spray on clutch facings. I also doubt that you will get enough lub. in the right place to have a lasting effect. 130 isn't that hard to split, just cut some good wood wedges to put in front axle pivot before you start. That offset engine can be a handful. This is not something you will have to do regularly. As soon as your new clutch wears in on old shaft it will be fine, unless tractor is left sitting for 5 years or more and rust sets in on shaft and clutch disc. I have split these little tractors many times, if you have any questions please e-mail me. I have changed a clutch in one of these tractors in 4 hours. ( not always mind you.)
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
