Trans-coupling seal replace on H
Posted by Kelly C on September 13, 2002 at 19:44:53 from (63.171.43.140):
third party image
Ok I got the seal to the liftall in...YEA!
Now I need to do this one. I have the shaft from the clutch removed and I have the bolt in the center removed.
How does this one come out? not screwed in also is it?
I also noticed some play or wiggle if you will.
From transmision side after I removed the shaft to the clutch. I hope a bearing is not bad :-(
Post A Followup
: Re: Trans-coupling seal replace on H
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
