Re: SMTA Steering
Posted by Andy Martin on September 22, 2002 at 07:17:35 from (12.74.160.19):
In Reply to: SMTA Steering posted by Farmer on September 21, 2002 at 19:14:44:
My experience has been that it is usually the lower bolster bearing. Jack up the front of the tractor and try to push the front wheels sideways. If there is lateral movement in the entire assembly then the large sleeve bearing right behind the grease zerk near the crank stub on the front of the tractor is loose. It will make the tractor wheels wobble and is the culprit. I've never had a bad worm gear or little ball bearing out of 11 M's and 4 H's. Of course anything can go bad so determine what it is before fixing it and you will save time and money. The big cast inverted Y that the vertical steering shaft goes through is called the "bolster". It connects the two frame rails together. So there is an upper bolster bearing and a lower bolster bearing each with seals. Modern grease works well in steering gearboxes so if you have bad seals and aren't restoring to total perfection put grease in the gearbox.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
