Have I found hubs for duals??
Posted by Bryan on September 24, 2002 at 10:26:32 from (205.243.112.50):
I found a set of hubs which appear to be duals for a tractor. They appear to bolt to the cast center of the inside rim with four bolts. (Approx 11" on center bolt holes)Then they are about 12"-16" long and have 9 studs on the other end. Heavy cast iron things they are, roughly 80+ lbs. They are marked Kalida and I have found a manufactuer in a town by that name that makes wheel systems but can't find any reference of these exact parts. They won't fit my 460 because my bolt pattern is 12" on center so what are they for? Also, how does the 9 bolt pattern work, do you have to buy a special rim for that? Thanks for the help!
Post A Followup
: Re: Have I found hubs for duals??
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
