Re: Help! Calling all Alis Chalmer Experts!!!
Posted by COWBOY on September 28, 2002 at 13:18:35 from (12.149.225.90):
In Reply to: Help! Calling all Alis Chalmer Experts!!! posted by Justin NY on September 28, 2002 at 10:45:07:
Howdy,... When I get into a bind and can't get the correct parts (Packings), you will have to improvise like I do. I usually take a sleeve to a Hydraulic Shop and match up O Ring's that will fit into the groove and take up most of the space but isn't much larger than the OD of the sleeve when installed. If they are too large they will get cut uneven when trying to install them in the block and most likely leak. Usually the O Rings are thinner than the groove as most packings are half moon shaped and not round. Then I use Permatex Ultra Blue sealer on the sleeve groove, then install the O Rings, then more silicon on the top of the O Rings. I also use a ball hone in the lower end of the block and put a thin coat on the block bore then install the sleeve and hold it in with a clamp or weight a few days. Only silicon the lower section where the packings contact as the head gasket seals the top end. The Ultra Blue Silicon works well. I have had to do this on over 100 sleeves to date and no leaks. Some have been in use over 10 years with no problems. The Ultra Blue Silicon expands and contracts better than just the straight Blue Silicon, and bonds better to the parts. I know this is not what they reconmmended when these wet sleeves were made, but they didn't have Silicon Glues and Seals back then anyway. The only drawback in doing it this way is it must be very clean, and to remove the sleeve at a later date, you will need a Sleeve Puller and can not tap them out like some folks do. If you need more detailed info, E-Mail me.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
