Old Raceway M-Main Bearing Report
Posted by The Red on September 30, 2002 at 14:46:18 from (12.84.243.222):
OK, I got the oil pump pulled and pulled the center lower main bearing. There is a distinct impression in the bearing that is centered over the oil hole of about 1/2" wide. I don't think the camera would pick this up. The main journal has a discoloration to it in the exact same area. I thought I could feel a very very slight rise from the discoloration in the center of the journal. Also, I checked the torque on the bolts. Someone had these torqued to 80 footpounds!!!!!!!!!!!!
Two questions.
1. I am trying to determine if this is a standard or oversize bearing. The number stamped on the bearing is MB 01063. Below that is stamped G41. I think my engineering neighbor has a micromoter if we can't determine whether it is standard or oversize from these numbers.
2. What can I use to try to clean up the slight corrosion on that journal? Keep in mind it feels smooth but I think there is a very slight rise in the diameter where this discoloration is. The discoloration is not even all the way around. It it is only on about 1/2 of the journal. It is obvious that the crank sat in one position for a very long time. I didn't drop the other caps so I don't know if this is an isolated incident or not. I am definitely ordering new main and rod bearings.
I appreciate the help Farmallers!
Post A Followup
: Re: Old Raceway M-Main Bearing Report
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
