Re: Magneto timing:
Posted by gene b on October 12, 2002 at 01:52:44 from (67.251.189.44):
In Reply to: Magneto timing: posted by Ajackr on October 11, 2002 at 21:54:31:
when #1 is on compression the mark at the flywheel should be straight down and say TDC you will have to clean the flywheel to see the mark. take plug out so you can look inside cycl to see the piston fully up remember compression. You can tell by putting your finger in the spark-plug hole as it is turned over with a crank or the starter. IT is best to have all the plugs out. #1 is the one close to the radiator. When you have determined that you are on TDC and piston is completely up take off the magneto cap and see if the rotor is pointed to the #1 wire going to the plug. The rotor can bemoved by taking off the two screws next to the rotor shaft and turning the rotor shaft so that the rotor points to the #1 terminal. You are now ready to fire up. A slight turn of the crank the mag should snap and rotor will jump clockwise ahead turn crank again till #3 comes up and rotor should be lined up with the next terminal on the cap as the firing order is 1342 and that is stamped on the block. Tha mag can be installed 180 out of correct position. If when #1 Is on TDC the rotor is pointed to #4 terminal on cap you are 180 out and the mag will have to be removed by taking the two cap screws out and turning the mag over 1/2 turn. If the procedure is followed and things arent lined up correct the gears arent lined up and the front cover will have to be removed. THIS is another procedure and we will cover that if neccesary. This should get you going.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
