engine dies on cub
Posted by pmtoolbox on October 13, 2002 at 04:27:39 from (152.163.189.203):
engine dies on my cub if you run it about 3/4 throttle. checked the fuel level and float . Ignition is good. runs fine up to and including 1/2 throttle. engine has been restored with new bore and pistons Compression is good. Acts like at higher rpm engine siezes. when it cuts off if you hit the starter right away it will not turn over motor. let it sit 30 seconds and it will start right up.this happens on a run of about 1/2 mile or better. Any Ideas? Thanks, S......
Post A Followup
: Re: engine dies on cub
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
