Hey Sean in Calgary
Posted by Larry in CO on October 15, 2002 at 19:10:56 from (32.97.110.142):
Sean, I noticed that no one replied to your question regarding detergent and non-detergent oils. I'll do my best to try to explain it. Way back when the world was young, 'bout the only oil available was a non-detergent oil. This oil did not have the additives that the more modern oils have. Consequently, all the dirt and stuff that accumulated in the engine tended to stick inside the engine and settle to the bottom of the pan. Modern oils besides having detergents, have acid neutralizers, viscosity modifiers, and have suspension agents that hold contaminates in the oil rather than allowing them to settle out like non-detergents. If you have an engine that has been run with non-detergent oils most of its life and you put detergent oil in, you in all likelyhood will start loosening some of this crud up. You might be lucky and get by with changing the oil and filter fairly frequently for a while to remove the loosened stuff but you could end up plugging a line or passage. The best thing, in my opinion, would be to determine if you can what the previous owner was using. Of course, on a new engine rebuild, I would start out using detergent oil. Hope this helps and if I've given any false information I hope someone will step in and correct me. Larry
Post A Followup
: Re: Hey Sean in Calgary
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
