Farmall Tractors Discussion Board
Re: Bevel bolts for mounting implements on A
Posted by John C. on August 24, 1999 at 08:20:12 from (12.13.248.14):
In Reply to: Bevel bolts for mounting implements on A posted by Marvin on August 24, 1999 at 08:01:31:
I think that the implement mounting bolts are the same as the wheel lug bolts. Take one of your wheel hub lug bolts off and check to see if it threads into the implement mounting hole. If it doesn't, determine the nominal diameter and threads-per-inch and ask for wheel mounting lug bolts at the auto parts store. The hex head on the wheel lug bolt will probably be a size smaller than the regular implement mounting bolt head, but I think the two bolts have the same amount of contact area in the tapered section of the head. Hope this helps.
Post a Followup
: Re: Re: Bevel bolts for mounting implements on A
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
