Farmall Tractors Discussion Board
starting problem on M
Posted by DonO on August 24, 1999 at 11:06:51 from (206.196.56.101):
I recently bought a 1946 M tractor to use as a second backup tractor. Because it may set for along time between uses, and beacause it has a magneto, I figured I would forego the cost of a new battery, wiring, lights, etc, and just start it with the when needed. I then noticed the portion of the sleeve that engages the shaft had been torched off. I pulled th bolster off (not a fun job) and replaced the sleeve with a used sleeve from a tractor salvage yard. When trying to put the bolster back on, I noticed the sleeve was too long and would be permenantly engaged to the . The used sleeve a got was the same length as several other sleeves I saw on other M's. The shaft looks normal on my tractor also. It appears the only way to solve the problem is to shorten the sleeve. Has anybody else had this problem or know what I'm doing wrong?
Post a Followup
: Re: starting problem on M
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
