Re: Farmall Super A Tranny and rear end??
Posted by Haas on October 22, 2002 at 20:39:24 from (152.163.189.203):
In Reply to: Farmall Super A Tranny and rear end?? posted by Bob on October 22, 2002 at 16:39:02:
This is a fairly easy split, certainly no more difficult that splitting at the clutch. I did it a while back on my Farmall C. One of the posts below mentions that you have to take the drive shaft coupling loose before you do the split. That is not correct. All you have to do is take everything loose on the outside(the throttle rods, the touch control rods,clutch linkage and anything else that goes accross the joint) Then support the front and the back (On the C, the back is nearly balanced). On the A, I would block the front axle with wedges and then support under the clutch with cribbing. You could rig an engine hoist to hold the back. Then you take out the bolts at the joint and the drive shaft will slide right out of the clutch as you roll back the rear section. I used long bolts in the joint holes as a guide. In my case, I had no trouble getting the drive shaft to slide back in the clutch when I reassembled. Just make sure you don't disengage the clutch while the thing is appart. If you do, the clutch plate will fall out of alignment and you will have a lot of trouble. You will need to take the drive shaft joint apart after you get things far enough apart to do that. That is necessary to remove the rear half of the coupling so you can replace the seal. You will find two shaft ends, bottom one is the counter shaft end, covered with a cap and gasket. That was where mine was leaking, as someone had reassembled without the gasket in the past. Top shaft is the main drive shaft and has a seal that runs on the coupling half and also a gasket under the seal holder. I'd replace all the seals and gaskets while you have it apart. Also make sure you have both dowel pins in the joint. One was missing in my C and the hole it was supposed to go in was open all the way into the transmission, also causing a leak. Hope this helps.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
