Re: It is a Ford !
Posted by JMOR on March 28, 2009 at 09:47:52 from (76.187.218.177):
In Reply to: regulator smoking posted by Bob 35 on March 28, 2009 at 08:26:36:
Jim, I'm not sure what gen type a 640 has, but if it is a type "A", where the regulator controls by grounding the field, then that is same as 8N Fords and if he applied battery power to field, then he probably did weld field points closed.
If he read on Ford board that you polarize by applying battery power to the Field, then he was likely reading about a NAA, Jubilee, or later tractor where the Gen is type "B" and control is by reg supplying power (not gnd) to the field.
OK, I just figured out that you apparently have a Ford 640, not a IH640, so you probably polarized correctly as it is type B.
This post was edited by JMOR at 09:54:31 03/28/09.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
