Farmall H live hydralics belly pump reservoir
Posted by Steven@nd on November 01, 2002 at 18:25:57 from (12.23.184.242):
Here is a diagram I scanned in from an M&W catalog on how to use the belly pump as a reservoir for live hydraulics.
Questions come up all the time about it so I'm also going to include how to plumb it: Pump suction should come from the hole shown in the diagram (3/4"). Pressure should go to an open center spool valve. Return from the spool valve could either go in a T fitting on the fill hole, or a T fitting in the suction line for the pump.
Also, a live hydraulic pump from a Super H, 300, or 350 will fit on an H if you change the timing cover to one from a SH/300/350. You should also use the cam gear from those as they were built heavier.
Hope this helps someone out!
third party image
Post A Followup
: Re: Farmall H live hydralics belly pump reservoir
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
